Reason for Pressure drop between the discharge of chiller and Suction
We have Chilled water system with Three Chillers catered by Four Primary Pumps and four Secondary pumps primary pump flow is 155 Meter cube per hour, where as secondary pump is 117 M3 per hour.
The suction at Secondary pump is negative Inlet pressure to Chiller from primary pump is 1.8 Kg/cm2 outlet is 1 Kg/cm2 and suction of secondary pumps are minus 0.8 Kg per cm2.
Both the pumps are grundfos why there is pressure drop of 1.8 Kg/cm2 {1-(-0.8)}
RE: Reason for Pressure drop between the discharge of chiller and Suction
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
Mike Cool
Mechanical Engineer
American Stainless Pumps, Inc.
Los Angeles California USA
www.aspumps.com
Best regards
Morten
Bill
"Why not the best?"
Jimmy Carter
