Advanced Filter Function Exclude
I am trying to exclude lines which only contain " - " Space,dash (Char 32),space. I have tried just about any combination with <> (not equal) but excel is ignoring it.
If I use ="= - " it will filter only these lines, but I can not exclude them.  Has anybody a solution?
RE: Advanced Filter Function Exclude
not able to open attached file . . .  please try attaching file again using "STEP 3" in posting procedure.
Thanks!
-pmover
As pmover said, your file is inaccessible.
If your doing this with a macro, I'd do something like this:
1.  Have a cell in your spreadsheet (e.g., A1)with " - "
2.  In your macro make a variable refer to that cell (e.g., A$=Range("A1")
3.  Have a condition when your data in a cell = A$
Have you tried ="<> - "
It seems like the ="<> - " gets rid of all, but one of the ones with just a dash.  The one that it misses doesn't have the space after the dash.
Great, this is the solution. Yes, the one which is not filtered needs a space after the dash as all others do.
Thanks for the tip.
