NFPA 1983 Certification
looking for leads for entities that can perform certification of these products.
TIA
TIA
RE: NFPA 1983 Certification
http:
or contact :::
http://www.ropecord.com/default.html
do you work for a fire department or someone else????????
thanks anyway.
need to find an entity similar to UL.
do you work for a fire department or other sgency, it would help to know to maybe direct you to what you are looking for?????
Once again if you look in nfpa 1983 it has other standards (non-nfpa) that the item has to be tested to. like meeting an astm
do you have a copy of 1983??
one more contact::
http://www.seinet.org/
http://www.seinet.org/seitestinglabs.htm
one section example:::::::::::::::
General-use life safety rope shall have a diameter 12.5 mm (1/2 in.) or greater and not more than 16 mm (5/8 in.) when tested in accordance with Section 9.1 of Cordage Institute Standard CI 1801, Low Stretch and Static Kernmantle Life Safety Rope. For the purpose of reporting, the calculated diameter of all new life safety rope shall be rounded to the nearest 0.5 mm (1/64 in.).
"""""""in accordance with Section 9.1 of Cordage Institute Standard CI 1801""""""""""""""
i know the standards (including ISO) but in order to certify the product the certifying agency must also be certified to certain standards in order to accomplish certification.
http://www.riggingforrescue.com/index.htm
"Fire suppression is a failure in prevention"
