Automate PDF output
Automate PDF output
Automate PDF output
Has anyone tried to export a library of prints to PDF with the use of Pro-E 2.0? I wondering if there is a way to automate it and not have to do each print individually?
RE: Automate PDF output
You can automate this and many other things with mapkeys or even trail files.
Pro_batch.bat is what you want for doing batch printing.
See the following for information on PDF creation with Pro/Batch.  Some info regarding Ghostscript and FreeDist may not apply to later versions of Pro/E but the Pro/Batch section should still be valid.
http://www.profilesmagazine.com/p25/tools.html
Fighter Pilot
Manufacturing Engineer
