Calculating serpentine belt loading
I have a 1954 Dodge truck I have retrofitted a 400 big block V8 Chrysler into it. I'm planning on twin turbo, and twincharging it. I have two Holset HX35's on it, and plan on fitting EFI. I plan on running compound boost using two Eaton M90's, similar to the WWII bomber aircraft engines. The two holsets will feed into the M90s. The question i have is on belt loading. Ideally, Id like to run a single 8 rib belt of the crank up to a jackshaft, then, drive the first blower off that jackshaft, and the second blower off the first by putting a double pulley on the snout of the first blower. Question I have is this:
Does anyone have any equations to calculate the power transfer ability of serpentine belts?
Each blower will consume about 35HP at full load, so I don't anticipate a single belt will be able to drive both from the crankshaft, but, I want to run the equations to be sure.
RE: Calculating serpentine belt loading
You need a considerable safety margin to cover load from pumping against boost, variations in friction due to rotor clearance changes from temperature changes. You also need to survive a backfire.
Blower belts tension also varies considerably due to engine expansion from heat.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Its also depends of course on the type weather you get but here, lets say, it varies!
Brian.
I made the mistake of not cutting my displacement in half to acocult for the 4 stroke engine design. As such,I dont need to run the blowers as fast, only at a 1.5:1 ratio. At a 1.5:1 ratio, they only consume 9-10 hp a piece, for a grand total of 18-20ish, which is much less than a single blower running at a 2.5:1 ratio like I originally had factored. As such, I *Think* I could actually get away with a single belt, so long as I get good wrap of the pulleys.
