Steel beam connections
Quick question - Table 10-1 in AISC 13th edition lists the beam web available strength per inch thickness for beams that are coped at the top flange only, coped at both flanges, and not coped. What if the beam is coped at the bottom flange only?
RE: Steel beam connections
d(act) = h - d(cope), use d(act) to check end shear.
