Global Variable in Equation
To tryout Global variables, I am adding a equation to a dimension in sketch.
LENGTH = 1
"D1@Sketch1" = LENGTH
SW says incorrect syntax.
Whats wrong here?
LENGTH = 1
Whats wrong here?
RE: Global Variable in Equation
"D1@Sketch1" = "LENGTH"
You need the quote marks around the GV.
h
h
"SurfaceArea" = Part.Extension.CreateMassProperty.SurfaceArea
I got that somewhere digging through this board way back when. Just be careful, it's apparently always metric.
What you have there is VBA. You can put any valid single line of VBA into an equation.
-handleman, CSWP (The new, easy test)
