PULSATIONS IN A TWO PHASE FLOW LINE
Hello to all,
We have a 12" line downstream a control valve station with two phase flow of crude oil inlet to a distillation column, the line is 15 meters long.
We prefer to leave the control station in place, can someone assist in a solution to eliminate the pulsation of the line? In reciprocating pumps a dampner is installed in inlet and outlet lines, can such a solution be adopted here?
Regards and happy new year,
roker
roker
RE: PULSATIONS IN A TWO PHASE FLOW LINE
However, depending on what you are pumping, installing some form of a positive displacement rotary pump would have stopped this problem all together.
IF i understand your question correctly, yes, you can install a dampner.
Or is it high turbulence associated with flashing??
My sense is that pulsation would be associated with some type of feed tray hydraulics. Could possibly modify the feed tray.
High turbulance would be a continuous "water hammer" effect from the flashing.
You may could elevate the control valve above the feed point.
You could move the control valve closer to the feed nozzle (mount directly to tower ??)
If it is not feasible to re-locate the valve but the pipe can be modified, then it may be possible to alter the flow regime by adding an internal spiral turbulator.
