API 600 Gate Valve Open Position Limit Switch
Does anyone know about API 600 Gate Valve Open Position Limit Switch?
RE: API 600 Gate Valve Open Position Limit Switch
Your real problem is how to integrate or mount on valve.
If rising stem you could use a flag on the stem and mount approximate switches to detect the flag. Switches mounted separately with mechanical adjustment of position possibel.
And/or if non-rising stem the best way technical is to mount a manual gear with integrated or possibillity to mount limit switches on the gear. Several suppliers.
You also need to know the electrical hazardous area classification as well as the sensing voltage and current. The length of the travel also varies by the valve size.
