Slip contacts on lock-out relays
I'm trying to envision how the 'slip contacts' work in a lock-out relay. Does anyone have a good description(or graphic/animation) of this process?
thanks
RE: Slip contacts on lock-out relays
I've never heard of slip contacts being used for lock-out relays.  Normally they are used as "memory" contacts for breaker control switches.
The link below may help.
http://www.gedigitalenergy.com/products/brochures/GET-6169G.pdf
"Theory is when you know all and nothing works. Practice is when all works and nobody knows why. In this case we have put together theory and practice: nothing works... and nobody knows why! (Albert Einstein)
By "Slip contacts" you mean latched contacts (that remain in changed position even after the control power to trip relay is disconnected!
These are reset by reseting the latch by manual action ("Hand Reset") or through electrical action ("Electrical Reset") by pushing a Reset button.
