Engineering Power Tools - Slenderness Ratio
Good morning and Merry Christmas.
My question is in regards to buckling in columns.  I started using the Engineering Power Tools download to check my calculations.  I have run into two challenges I hope you can help me with.
1. I get a different critical load when using Johnsons formula.  I have checked my hand calcs over and over.  I know it is right as I am using a textbook from college for a reference.
2. The slenderness ratio calculated by the software is different than what I solve.  I also noticed the slenderness ration does not change when the end conditions are changed (ie fixed-fixed, fixed-free, etc).
I am calculating the slenderness ratio by multiplying the end condition constant (K) by the length and dividing the result by the radius of gyration.
Is this wrong, or is there a flaw in the program?  Any thoughts?
Daniel
RE: Engineering Power Tools - Slenderness Ratio
Yes, you are correct.
Try a few cases with different end conditions (set L/r = 1) and check the results (k). If still do not agree, send them an inquiry and let us know the answer.
Thanks for the input, cntw.  I have sent an email to their support group.  I will let you know the response.
Does anyone else use this program?  I just downloaded it yesterday as a coworker pointed me in the direction.  I have let him know of the issue I have, but have not heard a response.
Hi GTDan
I have not used the tools to which you refer however I have a link here to another online calculator which might be of use:-
http://www.tech.plymouth.ac.uk/sme/desnotes/buccalc.htm
The slenderness ratio is L/r where L is the length of strut and r is the least radius of gyration of the section.
desertfox
Thanks Desertfox.  I will check them out
Euler's equations work nicely....I use them routinely.
