Bad Plate Results - Shear Near Pinned Edge
I'm getting unusual out-of-plane shear results for a simple plate model.
Model Description:
1) Program = RISA
2) 30ft x 30ft x 2ft thick
3) Elements are 2ft thick (out of plane) x 1ft wide x 1 ft tall
4) top edge is pinned out of plane only, free otherwise
5) sides and bottom edge are fixed
6) loading is triangular, based on fluid: 0ksf at top, 2.73ksf at base
7) E (modulus) based on f'c = 4ksi
Problem:
a) Horizontal shear Qx along top edge is very high
b) The rest of the model results agree with solid mechanics theory, except the top.
c) Top reactions agree with theory.
d) Vertical shear Qy agrees with theory.
e) Attachment: pdf plots of Qx, Qy, Mx, My
So here's the question: Is there a good theoretical explanation why the out-of-plane shear along the top edge (i.e. beam action horizontally) is so high, or is this a modeling error?
Model Description:
1) Program = RISA
Problem:
RE: Bad Plate Results - Shear Near Pinned Edge
when I look at the deflected shape, it seems reasonable that the twisting moments would be increasing towards that top surface. If the twisting moments are there, it seems reasonable that there will be some shears there as well.
0.0 shear at point of maximum moment and 0.0 moment (but not zero shear) at point of inflection. Maybe that doesn't hold perfectly for twisting moments, but it certainly provides a rational basis for understanding those shear contours.
