Convert entities - can't select all contours
If you have a face with several open & closed contours, then create a sketch on it, select the face then click 'convert entities', why does SW only convert the the open contour(s), and not the closed ones?
Any ideas?
Cheers,
Simon
SW2009 SP4.0
RE: Convert entities - can't select all contours
Usually it just does the outer contour not the inner contours. Do you have an example or a screen shot you can provide?
Scott Baugh, CSWP pc2
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
Yeah, if you have multiple contours (end of a tube, for example) only the outer contour will be converted.
Dan
www.eltronresearch.com
Dan's Blog
To add the other comments.  Yes, that is the way SolidWorks designed it to work.  smile
Cheers,
Anna Wood
Anna Built Workstation, Core i7 EE965, FirePro V8700, 12 gigs of RAM, OCZ Vertex 120 Gig SSD
SW2010 SP0, Windows 7
http://www.solidmuse.com
http://www.phxswug.com
Yes, SolidWorks does convert outer most loop when you covert by clicking on a face but....
There is another way, not exactly what you want or may be........
select the face & also select one of the edges you want to convert(from inner or closed loop).......then click convert.......this way you can select which contour you want to convert from a given face.......
Hope this helps....
Gurjeet Singh
Pick the face and then the edge of an interior contour and you will get that interior contour to convert.
