Flapper Valve/Weir
Flapper Valve/Weir
Does anyone know who sells a flapper/weir gate that will act like a check valve but open in very low DP situations? I'm envisioning one like a pool skimmer flapper/weir but on an industrial scale and quality and instead of floating closed it would sink closed. (i.e bottom of the pool not the surface) I could make one but I always try to buy things off the shelf first.
I have a large concrete sump with internal concrete walls. These walls have several large openings to allow flow back and forth to balance out the sump. I want to add these flappers to 300mm x300mm square openings to only allow flow in one direction but they would have to open on little more than 1-2 ft head pressure. The water is warm & clean but process water not potable. I have 10 openings so if one failed it wouldn't be critical but I have very few maintenance oppurtunities to drain the sump so I need something very reliable or I would risk damaging several pumps and forcing an outage.
The reason is for separating out hot and warm streams of water to increase steam savings down stream in secondary processes.
-Thanks in advance.
-Thanks in advance.
RE: Flapper Valve/Weir
http://www.redvalve.com/rv/index.php
Steve
