LPILE to analyse non reinforced concrete piles???
I was wondering if anyone knows LPILE can analyse non reinforced concrete piles?
RE: LPILE to analyse non reinforced concrete piles???
Lpile will do it. You will need to input pile cross section.
You may wnat to look at Section 22 of ACI 318-08 for design flexural capacity of plain conrete.
J
I do not see any option for non reinforced concrete in the pile shape input section. If I put 0 for reinforcing bar value and run the analysis, it gives me some weird lateral deflection curve with -44 in pile head deflection. Am I missing something here?
thanks
www.PeirceEngineering.com
It did not work that way. Someone suggested to pick type 1 analysis from the options menu and that worked. In type 1 analysis, you do not have to input reinforcing steel.
thank you all for your response.
www.SlideRuleEra.net![[idea] idea](https://www.tipmaster.com/images/idea.gif)
www.VacuumTubeEra.net
A bored pile with casing, or concrete filled pipe pile may have some chances, but does LPILE handle that?
