Can you hide bodies in a drawing view?
I have a multi-body part where I want to make a drawing, excluding one body in the part.
If I go back to my 3D and I hide the body, the drawing view hides it too but I don't want to need to hide it in my 3D.
CSWP-Surf
RE: Can you hide bodies in a drawing view?
Make sure you have the 3D model open.
When the popup box opens, switch to the model, select (in the tree) every part body you want to show in that view.
Switch back to the drawing, and select "add all"
Update your view and you should be set.
