Vibrating Equipments 1950's
Fellow Engineers,
I have this 3 types of equipments which is placed in a table top which is constructed in the midst of 1920's and 1950's. I was task to design the table top, unfortunately we do not have any vendor data (weights, speed, etc.)
Here are the equipment models found in the machine
1. Cyclo drive
Model CVVM1-4160DA
ratio: 473
Service factor:
Input: 0.75kW 1800rpm
Output torque: 155kgf-m
Serial No. C5039985
2. Cyclo drive
Model CVVM2-4160DB
ratio: 273
Service factor:
Input: 1.5kW 1800rpm
Serial No. C5039807
3. Beier Cyclo Variator
Model CVVBMN5A-4215DB
Ratio: 121
Beier speed gauge: 0.2-0.8
Input: 3.7kW 1800rpm
Output torque: 205kgf-m @ max speed
505kgf-m @ max speed
Serial No. C5058413
If you have the data for these equipments kindly inform me at once..thank you very much
Happy holidays
1. Cyclo drive
Model CVVM1-4160DA
ratio: 473
Service factor:
Serial No. C5039985
2. Cyclo drive
Model CVVM2-4160DB
ratio: 273
Service factor:
Serial No. C5039807
Ratio: 121
Serial No. C5058413
Happy holidays
RE: Vibrating Equipments 1950's
http://www.smcyclo.com/
Russell Giuliano
Thank you very much. As per attached picture, Is 5000lbs possible for this equipment? In the picture in their website, it seems very small (around 500mm to 1m in size longitudinally) and this seems to be just the motor. The equipment I have attached in this thread is huge around 5ft high tall with a 1 meter propeller-like at the bottom..can you give me an advise what weight to be assumed? the equipment is about a half meter diameter.
Happy holidays
Russell Giuliano
