unbalanced forces and couples for pump
I am working on the foundation design for Flowserve DMX centrifugal pumps. I wonder if anyone knows how to calculate the unbalanced forces and couples for these pumps. I have been waiting for the vendor to answer my question but so far I haven't heard back from them. But I would like to have some preliminary design. Also does anyone know if they specify the foundation load at the bolt down locations or the actual length of the bolt if using concrete foundation. They do specify the size of bolt.
RE: unbalanced forces and couples for pump
They should give you the CG of each major component, the pump, the gearbox/coupling and motor/engine.
They may give you a foundation detail, which you should promptly throw away and make your own design USING THE CORRECT FORM TO FIT IN THE FOUNDATION AND THE CORRECT REBAR DIAMETERS AND DEVELOPMENT LENGTHS for your AB stress, diameter and YOUR concrete F'c. Mfgr virtually never get those right. Pay close attention to the bolt hole diameters, chair height and OF COURSE the locations. BE SURE YOU GET THOSE RIGHT. Tripple check and check once more.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
That would be the transient reaction torque that occurs during across the line start up, correct?
"The problem isn't working out the equation,
its finding the answer to the real question." BigInch
