Web between intersecting cylinders
Hello, I'd like to make a web between the two intersecting cylinders in the attached pic.  I tried the rib command but that doesn't work and says I can only have one open profile.  Any hints?  Thanks!
Engineering isn't about perfect solutions; it's about doing the best you can with limited resources. - Randy Pausch
RE: Web between intersecting cylinders
Thanks Scott, I think I know what you're getting at.  Unfortunately, I wasn't able to open up your file as we are still using '08 around here.  I did do a midplane extrude using the inner diameter silhouette edge of the tubes and that worked, but I need to be careful not to make the thickness too great or I end up with a gap at the cylinder/web interface.  I was hoping for a command that would blend the two by sketching a profile and providing a thickness.  Apparently, rib only works for planar faces?
Thanks BluTurtle, but I cannot open anything newer than '08.  Maybe it's time my company updated!
guimba,
I notice that you cant open 2009 file. SO I included few snap shots.
web1
web1
Its created using the rib feature.
Sorry abt the bad files links. Here are the better images.
Last try :
Hmmm...seems the rib feature only works when the sketched line does not contact either tube.  If I start the line coincident with one of the tube rims it says the resulting rib did not intersect the existing model.  Same on your end?
Nope works even when I gave a coincidence constraint for the ends of the line to both the cylinders.
While constraining, I selected the end point of the line & selected the edge of the cylinder & choose coincident.
