CUSTOMIZE "FILE NEW" MENU
I'm trying to have my File New menu read a custom .pax file located outside the default NX6 folders in a custom "Templates" folder & add my inch & metric model templates to the list.
I've successfully edited the default "ugs_model_templates.pax" file to point to my inch & metric model templates along with a custom jpg image. This works okay but I'd like to have a separate custom .pax file instead of editing the default to keep everything separated during upgrades.
I've done some searching including thread561-195643: NX5 New Part Templates. But still can't seem to get it right. I don't find a "UGII_TEMPLATE_DIR" environment variable in the ugii_env.dat. When I add "UGII_TEMPLATE_DIR=${NX_CUSTOM_DIR}\Template\" to it the File New menu is empty. I've added "C:\UG\Custom\NX6" to "custom_dirs.dat".
Does anyone have advise on this?
Sorry for the long winded post.
James
James
RE: CUSTOMIZE "FILE NEW" MENU
<Presentation name=
...go down to the place where it reads...
FileNewTab="Model"
...if you use the same exact name that the system's .pax file used, your entries will be ADDED to the 'Model' tab on the File New dialog (of course if you delete or edit the .pax extension on the system's .pax file, then the 'Model' tab will ONLY contain your entries). However, if you give it a DIFFERENT name, then it will be added as it's OWN tab, ahead of the current 'Model' tab, on the File New dialog. Also place all of your template and image files in this same folder (that way you will not have to use full path names when you reference these files in your .pax file as the systems will look in the same folder as the where the .pax file for any referenced part and images files).
Now set the following environment variable...
UGII_USER_DIR=
...to point to your 'user dir' (don't include the 'startup' folder in your path, just the folder that it's in).
Note that you can follow this same procedure to modify, augment, or replace the 'Drawing' tab (or any of the others) on the File New dialog.
Anyway, I hope this helps.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
So I'm assuming that by adding my custom startup path to UGII_USER_DIR in ugii_env.dat that I no longer need to add it to custom_dirs.dat for tbr files, right?
James
John R. Baker, P.E.
Industry Sector
Cypress, CA
You lost me there. How do you "add this variable to your Windows profile"? That's a new one for me.
James
John R. Baker, P.E.
Industry Sector
Cypress, CA
Merry Christmas everybody :)
James
