Vault Admin tool "Create PDF files in the Vault . . ."
I have decided to use the vault admin tool "Create PDF files in the Vault on normal check in of SolidWorks drawings". The tool does not work in SolidWorks 2009 so3. I talked to my VAR tech support. The VAR tested it and got the same results I had.  The issue is now in SolidWorks hands.
I am sure this worked in the past. Has anyone found a way to make it work now?
I do not like it, but I am thinking we will have to print PDF's by hand.
Standing
SolidWorks Pro 2009 x64, SP3.0, PDMWorks Workgroup, SolidWorks BOM,
HP xw8600, 64-bit Windows Vista Business, Service Pack 1
Intel Xeon CPU, 3.00 GHz, 16 GB RAM, Virtual memory 166682 MB, nVidia Quadro FX 4600
RE: Vault Admin tool "Create PDF files in the Vault . . ."
I have never tried it, never needed to.
I prefer to create my opn PDFs with stamps, etc.
Thanks for the info, good to know.
Chris
SolidWorks 09 SP4.1
ctopher's home
SolidWorks Legion
Standing,
We have that setting turned on in our vault but have not had that issue.  We turned it on at SW08 SP04 or SP05 and it has worked ever since.  Sorry to hear of your problem.
John H. Dunten, CD
Certified Drafter
Standing,
We've had it on for as long as Drafting Man, if not longer, spent time on SW 09 SP 3 and got everything authored the way it was supposed to. Perhaps it's because you're just turning it on rather than having had it on for some time.
Joe Hasik,
CSWP/SMTL/MTLS
SW 09 x64, SP 4.1
Dell T3400
Intel Core2 Quad
Q6700 2.66 GHz
3.93 GB RAM
NVIDIA Quadro FX 4600
Joe
You could be right. Have not heard anything from our VAR yet. I know that SolidWorks will find an answer and put the fix in SolidWorks 2010.
Note: We cannot upgrade. Money Managers say no.
Standing
