Grounding of DC for Substation Trip Unit
This is a question about how to ground a DC system.
Currently I am looking at two options and I don't know which is the right way (is one right and the other wrong?).
First where the -ve of the DC is tied to the AC ground system.
The second is where the DC system ground is isolated from the AC system ground.
If people could provide me with some pros and cons of each. According to the Canadian electrical code if I isolate the DC ground I have to have a ground detector.
RE: Grounding of DC for Substation Trip Unit
When a ground occurs, the charger will alarm but very little current will flow.
There are several good threads on DC system grounding pro's and con's on this site. Try a search.
Yes, some type of ground detection is needed, but that is relatively simple to provide.
