New Coordinate System
Hello all,
I am fairly new to solid works. I would like to create a separate coordinate system on an existing part. It would be located elsewhere on the part. How would I accomplish this.
Thanks much
Thanks much
RE: New Coordinate System
Rob Stupplebeen
-handleman, CSWP (The new, easy test)
Thanks for the correction. What can you do with it though? An example of it's use would be great. Thanks.
Rob Stupplebeen
See also http://hel
I am starting with an assembly that has a brake drum as one of the components. There is an item that is located about the O.D. of the drum that needs to rotate about the center of the drum. I was thinking of locating a coordinate system in the center of the drum so I could pick a vector to rotate the part about it.
Thanks again
