Import Diagnostics greyed out
I have two parts imported with errors by someone else. I was able to run Import Diagnostics in one part and fix it. In the second part the "Import Diagnostics" line in the menu is greyed out. SW help does not mention anything about it. What is the problem and how can I run Import Diagnostics?
RE: Import Diagnostics greyed out
CBL: I did that before reading your suggestion and it fixed the model
Thanks.
