1953 AASHO Material Properties
thread165-109274: 1953 AASHO bridge specifications
I am trying to verify the material properties in several hundred bridges built around 1954. The design drawings reference the 1953 A.A.S.H.O. Standard Specifications for Highway Bridges.
The concrete is defined as: Class "F" Concrete.
Does anyone have a copy of this reference?
Thanks a ton!
Thanks a ton!
RE: 1953 AASHO Material Properties
Suggest you contact AASHTO directly - www.transportation.org
J
jdonville - doesn't everyone have a '53 AASHO?
