Can Ansys resolve structual deformation down to 0.1 nm
I am working a new project that involves deformation of glass from given loads on the order of  0.1 to 1 nanometer.
Does Ansys or Cosmos have the capability to capture this level of resolution?
Thank you for the help!
RE: Can Ansys resolve structual deformation down to 0.1 nm
Ansys most certainly does.  However, you should consider the units which you use in constructing and post-processing the model if this is the case.  Also, ensure you are using a double-precision solver.
-Brian
