insufficient memory ansys 11
Frecuently when running a simulation in workbench 11, a message "insufficient memory" make me sick. However I'm sure that it is not a true memory problem because I have solved the same dsdb before. It is noticeable that this error message always appear when I copy a dsdb. and rerun it with a new analysis or simply modifying something in the model.
(the mesh is also ok). Has anyone encountered this error? How do you fix it?
RE: insufficient memory ansys 11
