Pressure relief valve
I have to design a pressure relief valve. the cracking pressure is 500 psi. please guide me in designing pressure relief valve.
which book should i refer and also i need to draw the performance curve.
RE: Pressure relief valve
Also, check with the safety relief valve engineering forum under chemical engineering.
