asphalt content by ignition method
we need to determine the asphalt content by ignition method. We got a sample mixed by the plant per design and also we got an aggregate sample+binder separately. To determine ACF (aggregate correction factor), we have to determine the mass loss of aggregate during burning process, which requires to mix the aggregate and binder per design and burn it in the oven. I was thinking to burn just the aggregate without the binder to determine the mass loss of aggregate. In this way I think some of the error generated by the loss of binder stuck to the mixing pan will be eliminated. Am I overlooking something? We have an Troxler NTO oven. Thanks.
RE: asphalt content by ignition method
Never expected to hear about this process.
Or to have expected to hear about answers and specifications (or ovens, or pans) needed to fix problems with a process I didn't know existed. 8<)
