Lines With Arrow Heads
OK, it's that time of the quarter and I need to produce an actual drawing... Is there a way to draw a line/arc/spline with an arrowhead on the end (that is not a note)? If not and I have to cheat by putting an empty note (with leader) on the end of the line, how do I adjust the size of the arrowhead?
RE: Lines With Arrow Heads
Jeff Mirisola, CSWP, Certified DriveWorks AE
CAD Administrator, Ultimate Survival Technologies
My Blog
Chris
SolidWorks 09 SP4.1
ctopher's home
SolidWorks Legion
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
you can change the arrow head size of a single arrow.....try what I have written before.
Draw the leader ..........then right click on arrow head of which you want to increase the size.......last option in list should be size(in SWX 2008) & shange the size as desired........
If you still get the same result, you may need to get your VAR involved, or try resetting the registry.
What version and SP of SW are you using?
