Solid Edge vs DWF library
We are looking to transition to Solid Edge but have an extensive library of DWF published prints. Can SE use these and/or re-publish them to a different format. Is there a way to do it in groups or just individually. We have talked with people who have stated that SE will not utilize DWF files.
RE: Solid Edge vs DWF library
I don't see dwf files listed, though I'm a few versions behind.
However, if they can be converted to something like dxf then SE can open those.
That's was a previous employer had done.  Their old system was called Swift or something and they'd had some company do a batch convert to dxf or something like that.
http://anydwg.com/dwf-to-dwg-home.html
http://www.cad-2.com/dwf2dwg.htm
Are examples, I"m not recomending either just showing what turned up on a quick search.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Reading this
http://en.wikipedia.org/wiki/Design_Web_Format
it appears that dwf is AutoDesks answer to pdf, so I don't think CAD programs are going to 'open' the files.
There is a viewer available, so using your existing stuff should not be a problem.
There is also a creator that works as a print driver so you may even be able to carry on creating them.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
