FORWARD FLOW TESTING
Up front I apologize if this was covered somewhere else!
Q1: What are some of the typical "approved" and or listed design schemes being used to provide a means for meeting the forward flow testing requirements of 13/25 with system demand and hose stream?
Q2: Will a test of the fire pump at 100 % rated capacity achieve sufficient verification that the BF or RPZ meets the forward flow testing requirement in 13?
Q3: If there is not a fire pump on the system does one revert to the answers to Q1 above?
Thanks!
"Fire suppression is a failure in prevention"
RE: FORWARD FLOW TESTING
Please disregard found what I needed in 13 (A8.16.4.6.1)!
have seen a tee inserted in riser or fdc line after the check and a normaly closed valve and pipe open butt to outside.
Thanks Cda!
