Construction GFI breakers and GFI receptacles testing
Is there a NEC or OSHA requirement that Construction 120 Volt GFIC breakers and GFIC receptables be tested on a periodical interval?
RE: Construction GFI breakers and GFI receptacles testing
Most instructions say to test monthly.
Tests should be conducted and recorded or the constrcution company could be written up by the OSHA inspector. No different than the tests required on extension cords.
