Curve Number Problem
I am working on a stormwater runoff project in a desert area. There are about 500 acres of mostly bare sandy desert. If I look up a curve number from a list nothing is an exact match but urban desert with CN = 63 looks close. However, when I use the "Available Water Capacity" from the NRCS map unit description with an S value of 1.8 inches and solve for CN in the equation S=(1000/CN)-10 I get a CN of about 85. The difference is a max flow of 40 cfs vs 120 cfs using HEC-HMS.
I was wondering which one would most of you choose?
dpajr
dpajr
RE: Curve Number Problem
Mountain Type C/D soil
cover type - Barren (rockland, eroded and graded land)
quality of cover - barren
CN = 92-93
Alluvial Plain Type B soil
cover type - Open Brush (creosote, sage, etc.)
quality of cover - poor
CN = 82-83
Lava Flows Type C soil
CN = 90
from SBCFCD hydrology manual:
http
I ran it both ways. The difference is about 80cfs. Either way the client can't build on it. I am going with the higher numbers.
The referenced hydrology manual sounds like the curve number descriptions are a lot more complete than anything I have come across before.
dpajr
Where is your project site? Does the agency have guidance? Can you track down CNs for similar areas to verify the San Bernadino Manual cvg provided?
