My block is stuck in my end view boundry
I have a block that seems to be in the same view boundry as my end view. When I try to move my end view, the block(which is a chart, and is exploded) comes along with it. This happens to me often. What am I doing wrong?
Thanks to everyone and happy holidays!!!
RE: My block is stuck in my end view boundry
The only fix i have found is once I insert the block on the sheet, I copy it, then make sure I am not in the view & then paste it.
If the views are bigg & overlapping...........try to drop the block out of sheet & then drag it.
Then if I move the view the block also moves.
Standing
SolidWorks Pro 2009 x64, SP3.0, PDMWorks Workgroup, SolidWorks BOM,
HP xw8600, 64-bit Windows Vista Business, Service Pack 1
Intel Xeon CPU, 3.00 GHz, 16 GB RAM, Virtual memory 166682 MB, nVidia Quadro FX 4600
