Importing point file to 2d sketch spline
Hi, Everyone on here seems very helpful so I wonder if anyone out there has accomplished something like this. I have a file of points in x,y coords that describe a cam path. I would like to import these points as points in a 2d spline (almost like an "insert spline point" under the spline tools menu) so that I can do a wrap of the 2d sketch onto the cylindrical cam. I've attempted adapting some "import 3d points" macros out there into a 2d version but it never quite worked out. I'm not very proficient with code writing so I thought someone out there might know of a good way. I would appreciate any input on any level. Thank You
RE: Importing point file to 2d sketch spline
http://he
If you have trouble, post your point data and I can create an example for you.
Cheers,
Anna Wood
Anna Built Workstation, Core i7 EE965, FirePro V8700, 12 gigs of RAM, OCZ Vertex 120 Gig SSD
SW2010 SP0, Windows 7
http://www.solidmuse.com
http://www.phxswug.com
