closed center valve problem
i have a older case tractor with a bushhog front end loader on it, recently the inlet line on the control valve burst went ahead replaced both the inlet and the return line somehow they got switched durring installation now the loader arms go up but not down and the bucket tilts down but not up, it seems like the fluid is not flowing through the valve properly anymore what damage could of happen to the valve or componnets thanks scott
RE: closed center valve problem
Ted
Ted
Checkvalve in lines or integrated in valves misplaced or turned 180 degrees when mounted?
Mike Halloran
Pembroke Pines, FL, USA
