Comressor-VFD Setting Speed
The compressor minimum speed is 60%Nominal Speed. We need to set VFD to drive the compressor. I am thinking of setting VFD minimum speed at 30% Nominal Speed. Since we may run the compressor at lower speed later. Anybody can shed some light on me?
Thanks in advance.
Thanks in advance.
RE: Comressor-VFD Setting Speed
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
as jraef points out, the minimum speed is determined by the mechanical limitations of the system and the recommendations of the manufacturer. A lot depends on lubrication and the impact of running at low speed.
Will the compressor manufacturer honour the warranty? Probably not.
Will it break? Probably.
It's your compressor; do what you want provided it remains compliant with the applicable codes, but the manufacturer usually sets these limits because they are safe for the machine.
If only more people recognized that simple fact...
As others have said, you can set the VFD minimum speed to whatever you wish but on a reciprocating compressor, this is not a good idea.
The company I work for manufactures both VFD's and recip compressors for refrigeration. Our minimum speed is 40% of rated speed (30Hz on a 50Hz supply and 36Hz on a 60Hz supply). This is specifically for oil regulation. Maximum speed is also limited but for other reasons.
I would stick with the manufacturers advice otherwise it will get very expensive when it fails, and it will fail.
