A load transfer error was occurred
Hi there
I have one problem trying to run an analysis on Ansys v12. I have imported and meshed a geometry from catia in IGS format. But, when I try to solve the problem, this warning message appears:
A load transfer error was occurred. A load could not be applied to small or defeatured entity. ...
I have tried to do what is writen in the troubleshooting, (changing to other entity or with a finest mesh), but I can't success.
Do you know if there is a solution to this problem?
Thank you very much
