ASCO Red Hat II Solenoid Valve Solid Model
I need to get my hands on a solid Model of an ASCO Numatics, Red Hat II, solenoid valve model EF8210G004V. I have looked on the company website, and the other usual suspects, even searched here.  Does anyone know where I may find this valve?
MechEng13   machinegun elk
http://www.linkedin.com/in/alanetzkorn
RE: ASCO Red Hat II Solenoid Valve Solid Model
Chris,
Yes I found it as well, they just seemed to have the same models that were on the Asco website.  I did not see any others, especially the model I am looking for.
MechEng13,
Have you called the company on the phone?  Talk to an Application Engineer.  You may be surprised to find they have models and just do not post them online.
Then you could also let them know that having solid models online will make it more likely that you will use their product in the future.
Cheers,
Anna Wood
Anna Built Workstation, Core i7 EE965, FirePro V8700, 12 gigs of RAM, OCZ Vertex 120 Gig SSD
SW2010 SP0, Windows 7
http://www.solidmuse.com
http://www.phxswug.com
Thanks Anna,
I thought about that as well.  I may still do that, at this point I am working off calipers and mics to get what I need.  I am trying to get a decent nest for the valve in order to add the plumbing that is used in the assembly.
