some of functions are not working in solidworks 2009
thread559-226245: Hole Wizard error: cannot find swbrowser.mdb
dear sir/madam,
i recently installed solidworks 2009 on window vista 32 bit sp2 computer. software works good but some of the component and features does not work including extrude hole function and stating error given below
error: could not find tge standards database 'c:\program files\solidworks\data\databases\swbrowser.mdb'
thank you very much
cheers
Raj Verma
dear sir/madam,
thank you very much
cheers
Raj Verma
RE: some of functions are not working in solidworks 2009
-handleman, CSWP (The new, easy test)
When you open a windows explorer, can you see the file extension?
Standing
SolidWorks Pro 2009 x64, SP3.0, PDMWorks Workgroup, SolidWorks BOM,
HP xw8600, 64-bit Windows Vista Business, Service Pack 1
Intel Xeon CPU, 3.00 GHz, 16 GB RAM, Virtual memory 166682 MB, nVidia Quadro FX 4600
Question: The error, "Could not find Standards database 'c:\Program files\Solidworks\data\database\swbrowser.mdb'" displays when editing the Hole Wizard hole. How is this fixed?
Answer: Find the file SWBROWSER.MDB on the computer; if it is not installed, then the installation is corrupt and SolidWorks needs to be installed correctly
In SolidWorks, set the path in Tools -> Options -> System Options -> Hole Wizard/ Toolbox -> Hole Wizard/ Toolbox folder to be the same with the path where the file SWBROWSER.MDB was found.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
