Tolerance Question
Tolerance Question
I want to know how to tolerance the straightness of a bore in a shaft properly.
I thought it was cylindricity at first, but now thinking its concentricity to the outer diameter.
Any help, would be much appreciated.
RE: Tolerance Question
Concentricity actually has fairly limited application, one of the runouts is often a better choice or in many cases position is quite adequate.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Do you mean "TIR" or the included taper run out along the radius?
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
