Switching the view
Switching the view
Hello
How to switch the view to show parts covered by another feauture e.g when I assigne the section and I want to make another section in interior part of cubic.
RE: Switching the view
See the section 6.2.10 in the abaqus 6.9 documentation
6.2.10 Selecting interior surfaces
You can use the selection tools to select an interior surface of a model; for example, when you create a surface or when you select a region using the solid offset mesh tool.
To select an interior surface:
In the Selection toolbar, toggle on the Select From Interior Entities tool .
Note: The Select From Interior Entities tool is hidden by default. For more information, see "Using toolboxes and toolbars that contain hidden icons," Section 3.3.2.
Select the interior surface from the viewport
Hope that helps
