Over current condition
I'm looking for trouble shooting help to isolate problem of imbalanced current condition. Source power is 220 through Step-up transformer 3ph 480v to VFD (ABB 550). I'm running a 30 hp motor. The imbalance persists with varying the RPMs. Current is 8 amps higher on one leg at 1500 RPM. Not sure if motor is the problem or VFD.
RE: Over current condition
Current imbalance where? Probably between transformer and VFD, but not stated. Current imbalances don't happen in a vacuum, what do your voltages look like?
Current unbalance often follows a voltage unbalance. Or a blown diode in a VFD.
Bill
"Why not the best?"
Jimmy Carter
The over current exists at switchbox pre Xformer and on output of VFD to motor. Voltages @ output of VFD are good. Again, VAC output from VFD between the 3 legs and each leg to gnd. Also, VAC to the DC +&- connections. Balanced and consistant. I'm leaning towards the motor, maybe a partial short in the winding?
How did you measure the current between the VFD and the motor? Very difficult to get good measurements except from the VFD itself.
The current was measured with a Clamp-On Ammeter. Also note: I do not have the advanced control panal. Machine has remote panal mounted control with limited functions. (monitors pump pressure and RPM)
Don't measure VFD output current with anything not expressly designed for that purpose, you'll only see things to make you worry as it is anything but a clean sine wave. The best your typical clamp-on meter will do is current/no current and sort of a rough magnitude.
Point taken, although this started with 70 amp fuse blowing in switch box. Second time with clamp on meter attached to A phase reading around 65 plus amps then noting delta between legs of 8 amps consistant through output of VFD. Appears questionable with A phase 8 amps higher? bump up fuses and leave it alone or????
