Dimensioning bores
Dimensioning bores
I'm currently designing a parts catcher for a machine. Doing detailed design work is something relatively new to me so I'm unsure about drawing standards and dimensioning.
I have a shaft that is 45mm in diameter. A 'sleeve' will slide over the shaft. I require a clearance fit (H11). According to my Zues book a H11 fit for a hole in the region of 45mm dia would result in a bore size of 45.160mm.
My question is this:
In the drawing do I label the bore to be machined to 45mm with a H11 fit or do I label the bore to be machined to 45.160mm.
Also, could anyone recomomend a good drawing standards and geometric tolerancing book (SI)?
How do I then go about giving the machinists a tolerance?
Would the 45.160mm be my maximum bore size or would I have a tolerance +/- either side of 45.160?
RE: Dimensioning bores
has some usefull information.
Having worked in the UK, the old H11 etc fits seemed a bit of a hit and miss on if they'd be understood by machinists/vendors so I always used to give the actual dimensions on the print. Exception was on screw threads where I did just give the fit class info.
The tolerance on the bore is given in the fit tables. The fit tables give a range. So in your case I believe it's 45 to 45.16 HOWEVER for this to work properly the shaft will have to be toleranced similarly based on the same shaft/hole fit standard. Not sure what class your shaft as you don't give it.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
dang, KENAT, you beat me to the joke! ;)
Matt Lorono
Lorono's SolidWorks Resources & SolidWorks Legion
I was just going to go there, and you beat me to it.
Something like "Oh, so you've attended a Y14.5 meeting, have you?"
Evan Janeshewski
Axymetrix Quality Engineering Inc.
www.axymetrix.ca
I resemble that remark.
Gringy,
What is zues? I have heard that someplaces (ISO people)do not specify tolerance limits just like you referenced, are you ISO?
KENAT is right, the American standard is to explicitly specify tolerances (do the calculation for them).
Thanks, Now you just had to rub it in ;), I am jealous.
I am UK based.
The shaft is 45mm to 44.96mm dia. An H11 fit is stated to be 0 to +0.160mm. Therefore if on the drawing I state the tolerance to be 45.00 to 45.16 and the machinist cuts the bore at the lower end of the tolerance then I will end up with very little clearance. So should I bring the minimum closer to the maximum tolerance? 45.10 to 45.16?
Can any of you recommend a good book for drawing standards and geometric tolerancing (ISO)?
The shaft fit tables only really work when you pick both parts based on them. I don't see the fit you state for your shaft in my zeus book. Certainly it doesn't seem to be a c11 witch is the suggested match for an H11 to give a loose clearance fit. The clearance fit comes from both parts not just one.
Now if you want to emulate the minimum clearance from an H11/c11 fit you can achieve that by setting your min sleeve dia as 45.14 if I'm reading my chart right. However, since your shaft doesn't even match the tolerance range of a c11 you don't emulate the fit across the full tolerance range.
So, if your shaft dia is fixed then I'd use the chart for guidance, check with manufacturing what tolerance they can hold on the sleeve, check against your real functional requirements and go from there.
As to books, I used to just read over the standards but they aren't the most user friendly.
I'll have to make do with making the sleeve dia min at 45.14mm. For the function required of the shaft this should be fine.
Thanks again for the help and advice.
I are you new to the profession? Are you ISO schooled (non-US background)? Company standards inch or metric based normally?
I've been in the profession 11 years, in a maintenance engineering role. So I haven't really had too much to do with the creation of 'correct' technical drawings and the standards associated with them. I'm starting/trying to drift away from maintenace and take a greater role in the (mechanical) design of various parts for different machinery. (Although at the moment I appear to be making the odd mistake)
I am ISO schooled and my company is metric based.
For the application a stock bar is acceptable although I understand that there are potential issues relating to varrying dimensions and accuracy.
You give the dim on the print as: Shaft 45e8 and on the hole 45H11. On the bottom of your print in a special box you list all ISO Tolerances that are on your print for the machinists use. I.e. 45e8 = 45 -50/-89
45H11 = 45 0/+160
The reason for this will be clear to you once you get deeper into ISO tolerances and I do not want to get into this at this time.
As for a good book order the reference guide book "Tolerance Table for Nominal Dim.s 1 to 500mm as per ISO/DIN 286 from "Beuth" in English. ISBN 3-410-12677-5. Specify "English". It is a small and handy booklet for everyday use. Order some for the shop.
Go here for good info: http://w
And here: http://w
do you know ISO?
Jergenwrt & Grindy,
I have a thread on ISO 2768 and general tolerancing mehtods it in the ISO standards, I would like to know how you feel about working in that envioronment. Can you still use position on surfaces?
Tolerances under ISO 286 are given as for instance 12H7 or 12h6. Of the two systems "Standard Shaft and Standard Bore" most will use "Standard Bore (Hole)" since this system will save you money on gaging equipment and it is easier to produce a shaft at a tolerance required for a specific fit.
Reamers for instance are marked H7 and that is all you need in most cases and coming from a tool room background - one set of H7 reamers (2H7, 3H7, 4H7 etc.)is all that you will need. Reamers are not marked 12 +18. If you mark your print with the tolerance listed i.e. 12 + 18 the shop may not know that this is a standard 12H7 reamer tol..
Also by listing a tol. as for instance 12H7 for the hole and 12r6 for the shaft the shop can look at a DIN 7157 (sorry I don't know the ISO #)table and they will know what type of fit is required. In this case a light press fit.
In a separate block on the bottom of a print we list all ISO 286 tolerances on this print with the +/- call out.
used it in anger? I didn't catch that at first, what do you mean by that?
I mean does the ISO still allow the use of position tolerances on surface locations shown with basic dimensions?
Yes, ISO still allows the use of position tolerance on surface locations with basic dimensions. The meaning of this concept is the same as profile of surface tolerance in Y14.5.
I work for company that follows ISO 1101 standard regarding GD&T and I am not so happy with it as I think Y14.5 is much better, precise and logical (even despite few unclear issues like feature of size definition).
If I understood you well, you would like to consider all features of size simply as features?
I am not sure, I am really trying to understand why ISO doesn't have the issues using position on surfaces and we did. I do think the feature of size issue for us has created a problem that I feel was not necessary. In the 2009 standard now we broadened features of size probably because we limited it's definition in 94.
Shall I assume an American based foreign company then?
Also, I re-read this my posts and didn't see where I said anything about "used in anger", I suggest you give date & time reference in future.
"Zues is typically a pocket guide for machinists. I have one here on my shelf though I haven't
used it in anger
since I came to the States."
Ben Loosli
I also got burnt early on trying to use some of my old references even for US metric stuff since there are some differences. For instance head height on metric panheads found in North America is typically taller than in most other parts of the world.
The "in anger" part was the part that thru me.
Obviously, you can see I am trying to move my stuff else ware.
I do not know how to paste threads like you do
V
