Arid deserts effects on bare Carbon Steel or Corten
How will an arid desert such as that in Southern California, effect bare carbon steel(ASTM A36) or Corten A (ASTM A 588) weathering steel?
RE: Arid deserts effects on bare Carbon Steel or Corten
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
like presence of Atmospheric contaminants (SO2, HCl, organic acids), distance from the sea...but usually the corrosion rate in a arid desert is very low for carbon steel and weathering steel
this is from a paper of NPL:
"Weathering" or "slow-rusting" low-alloy steels containing 0.2-0.3% copper with minor additions of other elements corrode at about 3 1 to ¼ the rate of plain steels.
In the driest atmospheres, e.g.at Khartoum, the rate can be as low as 0.003 mm/year.
http://
this corrosion model by corrdefense is a useful tool to predict atmospheric corrosion:
http:
htt
http://
hope this help
S
Corrosion Prevention & Corrosion Control
