Change Hole Type
Change Hole Type
In NX 6 is there a way to change a hole type? For example if I insert a threaded hole but then later need to change it to just a screw clearance hole how can I do that? When I edit the hole all other types are greyed out.
Steve
Steve
RE: Change Hole Type
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
stThree: At least you don't have to recreate the defining sketch. Right click on your hole feature and select "Make Sketch External". Then delete the hole feature. Create a new hole feature of different hole type and pick that sketch for the points. Make the sketch internal to the new hole feature (optional).
