filling up closed water loop
Dear all, a few questions
1.Suppose a closed cooling water loop with an expansion tank at the suction side of the pump. When does one opt for a closed expansion tank without bladder, and when for one with bladder? If without bladder, do I prefill the tank one time with nitrogen, or do I have to install a pressure control system on the tank?
2.where to install the make-up water system. Is this pressure controlled feeding into the system when the pressure is too low? And where best to locate the make up system. Can I feed in make-up water based on level control in the expansion tank, without pressure control of the make-up water
thanks
thanks
RE: filling up closed water loop
