Internal Walls
Internal Walls
Internal Walls
I am currently working on a building with some interior masonry walls.  These walls are non load bearing (vertical or lateral).  Are there any requirements in IBC 2006 or ASCE 7-05 for applying an "internal pressure" to the walls?
RE: Internal Walls
IBC 5 PSF
RE: Internal Walls
That seems to ring a bell... but where is it in IBC 2006?
RE: Internal Walls
1607.13 Interior walls and partitions.
RE: Internal Walls
The 5 psf may be less than the lateral required for seismic depending on the wall weight and your location.  So, don't forget that aspect too.
Mike McCann
MMC Engineering
Motto:  KISS
Motivation:  Don't ask
RE: Internal Walls
Msquared
I am aware of the seismic in ASCE 7-05 section 13.3.
Thanks for the help.
RE: Internal Walls
I wouldn't design for less than 10psf.  Though IBC 2006 says 5psf the old Standard Building Code was 10psf.  Seismic usually controls in my area (>10psf) and I bet seismic would always be greater than 5psf in the u.s.
