HYSYS Selection of Property Package
Can anyone post a link to a website with a detailed explanation of which HYSYS property package is recommended for which types of fluids? My google search bogs down with a large number of sites showing how to select a property package (and not much explanation of which one to select). I'm personally only familiar with Peng-Robinson & ASME Steam.
My simulation has following components: Water, N2, CO2, CO, H2, H2S, O2, ethanol, minor organic solids
Thanks!
Thanks!
RE: HYSYS Selection of Property Package
For these reasons and simple problems (as those related to a design/rating of a valve) I prefer simple tools as Prode Properties which includes all the models you mentioned and are very easy and immediate to use...
Also I didn't intend to post this in valve engineering forum - whups! It should be in Chemical Plant Design or Process Engineering Forum.
Best regards
Morten
